TASARIM.02. (ABDULLAH) - PİRAMİT
- M. Rafet ÖZALP
TASARIM.02. Bugün nihayet uçtu.
göl kıyısında bir deneme yaptım çok rüzgar olmamasına rağmet güzeldi yani uçmaya meyilli aşağıdaki linkte görebilirsiniz...
http://www.resimgalerisi.net/AALP/sergi.php?sid=544
Hi Altan,
Many thanks for passing my message on to Abdullah.
I promiss to post a picture of the completed kite here for you to have a look at when it is finished.
Look forward to receiving the plans. If you want to you can send them direct to me via e-mail at the following address:
f dot kaz at btinternet dot com
(Just replace the dot with a . and the at with a @).
Once again many thanks
Fred
Fred
TASARIM.02. Çizim ve planlarını alttaki linkte görebilirsiniz
yapmak isteyenlere kolay gelsin
Hi Abdullah,
Many thanks for putting the extra pictures on linr.
I now have all the information that I need, but would like to ask the following questions.
1: What length are the Bridle Lines?
2: your picture 544_36/ image00004 middle picture what is the meaning of the picture
3: What is the small diamond shape above the diagram of the keel set up for?
Many thanks for letting me copy your kite and lookforward to hearing from you soon.
Many thanks,
Fred
Many thanks,
Fred
Denge ipi uzunluğu nedir?fred kaz wrote: 1: What length are the Bridle Lines?
image00004 anlamı nedir? Kuyrukları kastediyor.2: your picture 544_36/ image00004 middle picture what is the meaning of the picture
Keel üstündeki baklava şeklin ne olduğunu soruyor.3: What is the small diamond shape above the diagram of the keel set up for?
Hi Fred.
1- Abdullah will answer that.
2- Tails. Look at this sample:
http://www.resimgalerisi.net/galeriler/ ... 544_21.jpg
2 Tail attached at last part. You can attach tails if wind is good enough.
3- All diamond parts are same height. 120 cm.
