Making a kite for a school project
Cevapla
johntimber
Kayıt: Pzt May 07, 2018 12:46 pm
Mesaj gönderen johntimber » Çrş May 09, 2018 3:34 pm
Hi,
For science fair I was thinking about making a kite. The experiment would be on how the shape of the profile affects the lift to drag ratio and the amount of lift. This means that the kite must auto-zeinth so it can fly on one line to get accurate readings of the lift it creates. Also the kite will need to have its profile easily adjusted. An arc seems to be the best choice.One small problem though. What airfoil profile should the control be? Two different control profiles could change the results dramaticly. After some thought, I found a soulution. The kite will have no profile. The top and bottom skins will both be flat.
For More Details:-
Infographic animation company
Cevapla
Kimler çevrimiçi
Bu forumu görüntüleyen kullanıcılar: Hiç bir kayıtlı kullanıcı yok ve 3 misafir
